transatlantic":2e2l88di said:
So is the only problem with the router option the tear out? If thats the case, couldn't you just only make the cuts half way through, flip the board (or jig) and come through from the other side? Sure it'll be a pain, but it has to be quicker than using the tablesaw.
In short, no, you can't. Or at least you won't solve the tearout problem that way.
Think about the cutter at various points during the slotting process:
- It enters the wood going sideways. If it doesn't have a razor-edged corner, it will scuff and tearout at the top of the notch. You can minimise this by "marking out" with a sharp blade, equivalent to the spurs on a plane, but that's extra work.
- When it's gone in one radius deep, one side is pulling fibres directly out of the stock (the "climb-cutting" side). and there's usually no 'backer board' at the front (although you could add one, I suppose).
- At the back, it emerges going sideways, and the non-climb-cutting side is always going to pull at the fibres until the cutter diameter goes past the end of the stock. You can mitigate this with the backer board of the jig, obviously, but after only a few notches, everything gets a bit looser and voila! Tearout.
Regarding flipping the jig: I made a jig to cut box-jointed octagons. It was a nightmare to do, and the results (admittedly in softwood) weren't pretty.
That was mirrored, so you cut one end normally (pushing right-to-left across the table), and the other end in reverse. BUT... you need the registration pins on the "fence" side of the table* at both ends.
On the "normal" end, the cutter is pushing the stock towards the pins... but on the cack-handed end, it's pushing the stock out of registration - a disaster! I ended up with a long 8mm bolt clamping the stock edgewise against the registration pin, and even then it was slow and awkward.
Frankly I could just have cut them by hand, and they wouldn't have been much worse for all that.
E.
PS: mods to that jig could havbe been made to improve it - I have a better design in my head - but I lost interest. Might resurrect it at some point in the future though.
*obviously no fence needed in this context. I mean the side furthest away from you.
