ScottGoddard
So i bought a router table from someone on here a couple of years ago and just got round to setting it up! I bought the charnwood WO14 and then modified it to take a routalift from Axminster. When I bought the routalift it came with the bosch GOF 1300 ACE.
So, to the question. When i have the router lift all the way up the bit doesn't seem to come up very far. The example i have used is a slot cutting piece and it will only come up far enough to make a cut 5mm up the wood - is this correct?
I could lift up the bit a little bit not much...
Do i need different
i have attached some pictures.
Do i need different
