Karlywarly
New member
Hello thanks for letting me join . Any advice on router bits 1/4 inch Draper or Trend bits thanks
Thank you for your quick response , I’ll leave Draper alone and go along the Trend route . I bought a cheap set off eBay to see what bits I liked and you have been very helpful thank youWhat advice do you need? AFAIK Draper is a generic brand for Chinese tools, variable quality. I've found Trend customer service good. I bought a large dovetail bit from them last year for quite a large job with sliding dovetails. The millisecond the bit hit the softwood (with the bulk previously hogged out) a large piece of TC broke off. They replaced it very quickly and apologised. The replacement bit was fine and chomped through many meters of wood.
If you're new to routing, people often advise buying one of the Trend larger sets to get a feel for what you will need long term. They are then cheap per bit and as they wear out you can buy better quality replacements.
Good shout IMO on Wealden, always good service. Also look at Whiteside Machine Company bits from Router Bits UK | router bits, solid carbide spiral bits, boring bits, brazed tungsten carbide router bits. I use them for bits I can't find at Wealden and they are good quality IMO.
