Router bit top five?
29 Jun 2010
England
What are you top 5 or so router bits that you ACTUALLY use in order of times used?
mine as follows......
1) Recessing cutter for producing double rebates. For producing recesses with a lower rebate. Designed to accept librarybookcase strip. D1 12 mm D2 18 mm C1 10 mm C2 6 mm
2) 1 x Flush Straight Twin Flute with bearing: 1/2" shank
# 12.7 x 63mm long for kitchen worktop jigs
3 TCT round over router bit with guide bearing. Each cutter is supplied complete with 2 interchangeable guide bearings of a different diameter. This allows you to produce either a radius edge or and ovolo shape (stepped edge)
4 3.2MM CORNER BEAD A bearing guided tungsten carbide tipped cutter designed to produce a decorative edge when working on MDF, softwoods, hardwoods, and plywood.1/4in ShankRadius: 3.2mmDiameter: 22mm
5 rebate set with various bearing to adjust the width of the rebate
Hi,
1/2" end mill
1/4" cobolt end mill
1) Flush straight bit 1/4" with undersized bearing top (binding channels)
2) Flush straight bit 1/4" (finishing against template pocket routes)
3) Flush straight bit 1/4" with bearing top (edge finishing)
4) Flush straight bit 1/4" with bearing bottom
5) Flush straight bit 1/2"
Jim
Freud 30mm long 12 mm straight bit, but here is the important part; it the replaceable tip type. Magic and worth every penny.
Jim
