Router bit definitions. US and UK. Dovetail bits.
pe2dave
2 Oct 2007
Peterborough, Cambs, UK
I'm reading about a '1/4" 7.5 degree' dovetail.
Anyone know where those dimensions relate to please?
Might guess its the narrowest neck and the angle neck
to tip?
Dave
1/4" = D
7.5 degree = A - 90 degrees
Gidon
gidon":w0shbjd1 said:
What's nearly right - sorry don't get it?
Gidon
Sorry. My guess was nearly right?
I guessed the neck size, in fact it's the larger diameter
as shown on the figure.
Not many of the UK suppliers seem to provide those sizes
though. CMT do, but others just say '1/4" dovetail'
and leave it at that.
Dave
gidon":1xas39cx said:
What do you need that bit for exactly?
Gidon
Not that particular bit. I've invested in an US tool
and the bits are specified in that fashion. I'd never
seen it before... in fact never considered how dovetails
are specified (or under specified it seems in the UK),
hence the question which your diagram nicely answered.
So it was education as much as anything.
Dave
Glad you're sorted!
If you really want to get confused try using an (US) Incra jig to cut dovetails with Woodrat (Metric) bits!
Gidon
Feeling a bit dense today :) Is the drawing not to scale? How big is the shaft.
Regards Tom
Steve Maskery":18pq9emz said:
I would agree with that interpretation, but that must make for a very small shank diameter, wouldn't you say?
S
Never seen one, but like a small straight bit, I imagine the 'neck' of the cutter part is smaller than the shaft (unlike in the diagram).
Jake":1fzbt0kb said:
S
Sorry, my terms (knowing no other).
I meant the diameter at point 'C' on the diagram;
neck 'cos it's the smaller diameter of the cutting bit.
Dave
I hadn't noticed you used it too, and I think it is a fine term to use (as I would!)
pe2dave":3d3aqjff said:
motownmartin":3d3aqjff said:
I think This might be what your looking for Dave.
Yes, from Roger I guess.... I was trying to see how my existing
bits matched up.
Templates need tuning to the bits, which isn't easy.
Dave
You're not wrong there, I got in a right muddle trying to set the depth of cut :eek: so I bought one of these sets, now it's a doddle :D
