Red
I hear this is a fairly common issue, and I've looked at posts and blogs already, but I'm still in trouble.
I have got a 1/2" template bit stuck in my DeWalt DW625 table router. It's the only 1/2" I have, so it has it's own collet and was probably living in it in the box (I now realise this is bad). Now it is stuck in the router, bottomed out. I have undone the nut to the point where I can wiggle it up and down a little, so I believe it's completely loose. I've tried WD-40, whacking the bit down, gripping it between blocks to turn it, whacking it on the sides, levering under the bit until the router base bends (!!). At this point I'm willing to sacrifice the bit and collet if I can get the router back, but I don't know what else could help.
My last idea I haven't tried yet, is using the motor itself, and running it with the nut loose and forcing a hard cut. Dangerous, I know. But I'm not sure what else I can try.
Can anyone offer any tricks?
