if you are starting from sawn timber or wanting a dead straight planed edge for gluing, I would use a router with a straight bit and bearing like the disposable tip ones from wealden and run it against a straight piece of mdf or plywood.I had looked at a couple of options for a jointer. One being using the router table and the other was using my electric hand planer in a homemade jig. Maximum thicknes of wood will be 18mm for making mybbeehives.
Sounds like a Stanley no 5 or 5 1/2 then! You get peace and quiet, less dust, and can save fingers and electrons!Lengths are 460mm maximum.
To be pedantic you can't use up electrons, you just inconvenience them a bit.Sounds like a Stanley no 5 or 5 1/2 then! You get peace and quiet, less dust, and can save fingers and electrons!
Don't you know that they escape from the wall socket if the switch is left on?To be pedantic you can't use up electrons, you just inconvenience them a bit.
If we were on a different thread I'm sure we'd get asked how we know this.... ()To be pedantic you can't use up electrons, you just inconvenience them a bit.
To be even more pedantic the smiley was there to indicate that the preceding text was in jest.To be pedantic you can't use up electrons, you just inconvenience them a bit.
