Roofing
Digit
11 Nov 2007
Wales
Can anyone tell the name of the corrugated metal roofing sheets that have a layer of foam insulation built in on the underside please?
Roy.
Roy
I don't think there is a specific name for them - most metal roofing profiles are available with the foam and also without the foam.
HIH
Dibs
Cheers mate, I'll just try E-bay under roofing then. Currently my workshop has no insulation and a felt roof, needs replacing this year, but I use the roof beams to hold clamps, jigs etc so I don't want the insulation on the inside.
Roy.
Look for something like "insulated box profile sheets/roofing"
Ta! I've book marked that and will have a shufty later. (Please note, old time Shufty, not modern useage!)
Roy.
Bringing up and old topic here, but i found this topic via google as im looking to source something similar...
Did you ever find anything? Im looking to find a supplier of this sort of thing for my Roofing Supplies store.
Thanks.
Dave.
I did indeed, but found it far more pricey than the alternative that was on the cards, which was/is rubber and conventional interior insulation.
Roy.
