This cold weather has just made it too cold in my unheated garage to work, yes its been cold even in Swanage! So it has concentrated my mind on sorting out some insulation for the roof.
I have a pitched roof with breathable membrane above the rafters which are 130mm deep. Is it best to insulate between rafters, and if so do I need an air gap between membrane and insulation or should I put insulation under or even both! I'm not looking for high temps and am generally happy working if 50f or above.
It seems simpler to fix below the rafters will 25mm Kooltherm do the job? I'm undecided whether to leave this bare or skin with ply. I would welcome
any advice.
Jeremy
any advice.
Jeremy
