Woody2Shoes":2x6p1dr6 said:
Hi - you haven't mentioned what type of flue pipe you're using (insulated with a double skin would be my preference), but I would take extreme care that the flue pipe doesn't get too close to any combustible material (e.g. wood/sarking felt) I see from your photo that you're pretty close to a rafter for example. I'm fairly sure that there are rules in the Building Regs - e.g. Approved Docs B and J, as well as HETAS rules) re. separation of flue pipes from combustible materials and you may find it useful to use some glass-reinforced board e.g. glasroc to form a collar around the pipe as it passes up through the roof. I second/third the lead flashing option. Cheers, W2S
The research and reading list for this has been extensive on the varying legislation involved! Its taken longer to research it than its taken to select, collect and fit the various components.
Although, as it is not a 'house' where it is being installed, there appears to be a grey fog surrounding the relevant legislation that is applicable. A distributor of chimneys advised me that the legislation I quoted him, did not apply as it was to be installed in an outbuilding.
I also independently checked that opinion with a current HETAS engineer who gave me a completely different answer (but did advise on the size, material and quantity of screws required at each junction!)
Perhaps you could direct me to the specific documentation of which you refer for outbuildings? Certainly the fireboard, for the purposes of the national Building Regulations, is designated a ‘material of limited combustibility’ (Approved Document B). The surfaces of Gyproc FireLine are designated Class 0 (for the purposes of national Building Regulations). I really could have done without knowing that information and dont even get me started on the HETAS guide (2014).
I'm content that if I can fix the hole in the roof, I'm good to go and ALL relevant legislation has been exceeded even the no combustable materials within 50mm of twinwall flues as defined in BS 4543-1!
(There are more pics / details on the 'Game of workshop musical chairs' thread.)
So back to the question. As I'm in for about £90 on this flashing, I'd like to get it to work before investing further in a lead solution! The manufacturers suggest double sided tape to hold it in place! Nah, not going to work with these manky tiles ! lol The flashing is this one (although not purchased from this supplier), pure aluminium apparently, it is lead like in its malleability;
http://www.sunburstfireplaces.co.uk...5-450mm-11-18-inch-masterflash-high-temp.html
Thanks.
