RobertMP
Not a lot to show so far as I've been away for a week and only just getting back to things
The idea is to keep updating this thread as I do more parts and hopefully see it through to completion at some later date (later than I expect based on past form!)
Anyway the sideboard is for use in our conservatory and will be subject to a bit of heat. I bought the beech for it some time back and planks for the top have been in the conservatory acclimatising. They were also getting in the way so I have started with the top panel so that it can be stood up out of the way while I do the more interesting bits!
The boards.
Planer.
1st pass. Was hoping to end up with 24mm thickness but the boards don't seem flat enough.
all flat on one side after 3 passes. Then edged one edge on all of them.
Slit the short piece into 2 for the ends then thicknessed everything.
finished pieces. Came out to 22.5mm time all the sawn face was gone so not too bad.
Marked the edges for biscuit positions and made a simple jig to set the cut length when routing the slots.
ready for some glue!
I tend to be a bit heavy handed with the glue . Also learnt that glue is a pain to get off the bessey clamp bars with all that knurling - hence the plastic bags.
Watching glue dry. Put a steel rule across and it was nice and flat.
I made a quick cutting jig for the router thinking that would give me a nice straight square edge. It almost did but wasn't perfect so I gave the panel one light pass on the planer afterwards to make it true.
I don't have anything long enough to clamp the ends on so after cutting the biscuit slots I made some oak wedges and fixed end stops to the table. Apply clamps to the wedges... and it worked and squeezed the glue out! More plastic bags to stop me gluing it to the bench.
So plenty of cleaning up to do now. Joints seem fairly flush and I could level it with the 1/2 sheet sander. Now might be a good time to ask how I *should* level it off? I don't have a scraper - should I get one?
Once ready I thought I might give it a coat of sanding sealer with the idea it might help keep it stable until it gets a proper finish. Finish will probably be a polyurethane lacquer when I get that far. Sound like a good idea?
To be continued.....
The boards.
Planer.
