Cegidfa":2wi3p91j said:Definition of HiFi...the shortest route to bancruptcy known to man - far more efficient than the banking system.
Regards...****.
You should try sailing, it has been described as standing in the shower, ripping up 50 pound notes!
I am also into Hi-Fi, still have a fair bit of Naim but make my own stuff mostly now. I am a little confused about your term, "playing the mains". I have not heard of this before and have many friends and online acquaintances who have Naim stuff as well. Do you mean a mains hum, more likely to be an earth loop, Naim stuff is designed to have a very precise ground management with the source providing the only signal ground and all other equipment linking to that. The disadvantage with this is if the source is not adequately grounded then the ground is not tied down and "floats" and this can cause buzzes or hums. Equally if multiple pieces of equipment are grounded as well, the ground can act as an antenna and put noise in the system.
BTW I am not referring to the safety earth but the signal ground which is linked to the Earth but only at the source as described above.
