G S Haydon":2160k0ne said:It might be OK. I tried a 4 1/2 and sent it back as I felt it was not great value for money.
If you want the No5 for rough jack work I'd get a old Stanley or similar. When I say old don't go mental, anything made up until the 70's is a pretty good bet
If you want it as a bench plane for smoothing and edge jointing on small work then modern planes mentioned above would be good but the Stanley would also be fine. It might be just my luck but old planes don't need much more than an hour spent on them. If they do you chose a bad one!
The new route is a good one for sure but as an alternative perspective on the other responses, the money you save on a vintage one could be spent on wood. finish or fittings.
Best of luck whichever route you go for.
Each day (for ages and ages) in his workshop he would spend about 20 minutes flattening it on wet and dry on a glass plate. By the end said:Sounds like no one had the heart to tell him he was using the wrong side of the sandpaper. He should have used the rough side, so much quicker. :wink:
What was he using, worn 120 grit paper from HF? Sheesh.AJB Temple":391sgxmw said:By the end, after a about a year as I recall, he had a decent enough block plane and was very pleased with it.
I'll say!Corneel":391sgxmw said:It really sounds like that bloke with the Stanley block plane didn't know what he was doing. .
ED65":1pvrdar8 said:In a new plane I think the sweet spot in the UK for value for what you get might be Faithfull. You can pay quite a bit less for a Silverline but you're probably taking more of a chance with those.
With the Rider planes being subject to the same sorts of production variations as both these brands according to buyers (some need little work but others need quite a lot of work, and there is the occasional lemon) I think the main reason to pay the slight premium for one is for the ductile casting rather than common grey cast iron, which you'll be glad you paid a bit more for if you're ever unlucky enough to drop it on a hard workshop floor.
Another reason to choose one would be for aesthetics, if you like its lines (some Bailey-esque touches) and the brass screw cap, which I certainly think knocks a cheap-looking plated cap with a shoddily-cast brand name at the toe into a cocked hat.
But if you don't mind that the tool is old and might look its age to some degree buying a seconhand Stanley, Record or Woden will give you the most bang for the buck (for other brands worth a look, see previous thread). These can often be about the same price as a Silverline and sometimes much less, but they can be every bit as good a plane as any similar one made today including those at the pricey end of the spectrum (e.g. Lie-Nielsen).
Yes I saw the Quiangcheng sale at Rutlands, I already have a Quiangcheng No 4 smothing plane, very nice bit of kit. Is in my big airtight plastic box with moisture absorbers. Someone was very generous, the other day and gave me a brand new Clifton No 4 shoulder plane, can be used as a bullnose or chisel plane. ( expect you all know that anyway ) Beautiful little plane, really nice. Is in the airtight box too.woodbrains":87qrh26w said:Hello,
Rutlands are having a sale on Quiangcheng planes at the minute. Probably the best value/performance at the moment. I would still go for Veritas myself. I know it might seem like a lot of money, but they just work flawlessly. I started woodworking at what was probably the nadir of toolmaking. All my planes are heavily fettled old Records. I was young then and enthusiastic for doing mindless cleaning, flattening and tweaking, and I have a very good set of tools because of it. If I had the benefit of new Vertas tools then, assuming I had the means, I would have had a better set for no effort, and perhaps lots more woodworking projects under my belt because of it. The few Veritas planes I have added later have been gratifyingly superb. Admittedly, I have lots more tools than I actually need, because it was easy to come across cheap tools to fix up. Buying the better brands would mean less, but more useful tools in my kit. If time spent fettling is your thing, then second hand is the best bet for value and performance. Otherwise I'd get a few, well chosen, Vertas or LN, whichever is your preference, and get woodworking straight away.
Mike.
You need to discover the joys of waxed steelpollys13":1wgmh4k4 said:I already have a Quiangcheng No 4 smothing plane, very nice bit of kit. Is in my big airtight plastic box with moisture absorbers.
