beech1948
Well a bit tongue in cheek but also with a sense of annoyance at certain suppliers here is a review of some decking screws.
I recently built a deck which was 42ft x 12ft or 18ft at widest point. I used Screwfix for most of the screws and later in the build I used some from B&Q and some SPAX screws from my local shop. So a chance to record the useability or not of three brands.
1. Screwfix Decking screws:
Used 2000 of these
Green coloured with some kind of protective coat. Head looks like a Pozidrive 2 but is'nt quite. A PZ2 bit cams out very easily. Screwfix claim its a Prodrive 2 so I bought some Prodrive 2 bits from them. These were worse than the PZ2s and cammed out very easily. Screwfix stumped when asked to explain.
The cam out problems were partially solved by being very very very very careful to line up my cordless drill so that screw and drill and hole direction were all aligned very closely. BUT still getting 10 out of 20 that cam out to soon. Heads of screws were quite frequently destroyed by this so 3 or 4 per 20 were withdrawn and thrown away.
These screws were very hard and very brittle. Heads would easily break off. Heads were frequently made very worn by the drill bit.
The screws were not straight. Often had a bow in them which produced a 3-4 mm circle at the head/bit interface. If I leant too hard on them then this bow would become a large banana shaped curve and the screw was withdrawn and thrown away. Again 3-4 out of 20.
Holding power was great. Getting the screws into the wood was poor. I tried both cordless ( 2x makita) and mains powered ( Bosch ) and several different torque settings.
Verdict: Screwfix deck screws are very poor, with low quality control and porr repeatability. Generally so bad I would say they were rubbish.
2) B&Q.
Used 300.
Straight forward does what it says on the tin. Well made. Well protected by grey covering. Straight. Easy to drive in and out. Everything the Screwfix ones wern't
Good screws. Would buy again although a bit pricy.
3) SPAX. .
Used 250.
Wonderful. Straight forward does what it says on the tin. Well made. Well protected. Straight. Easy to drive in and out. Everything the Screwfix ones wern't
Good screws. Would buy again although pricy.
Verdict: Stop being a cheapskate and buy more expensive screws and in future ignore Screwfix for anything specialised such as decking screws. Probably continue to use Screwfix for more normal volume things.
As a general note though I have found that my local DIY/hardware store has started to stock boxes of screws ( SPAX ) which are only about 15% to 20% more than the Screwfix prices so guess where I will go in future. They are even open on a Sunday..brilliant.
regards
Alan G. Beech
Used 2000 of these
2) B&Q.
Used 300.
3) SPAX. .
Used 250.
regards
Alan G. Beech
