Hello!
I have a few questions regarding an old wooden box I would like to repurpose.
I don't know what type of wood it is, but have attached a few images to the post incase anyone here knows! (I am very new to this hobby).
The finish on the box is now quite dirty and I have wiped it down with soapy water. I've removed the hinges and other fittings to clean them also (using ketchup to refresh them!)
I have no idea what finish is currently on the box. I'm tempted to remove the finish - is this a good idea? If so can you recommend what type of product I should use to do this (especially as the current finish is unknown).
The previous owner had screwed fibreboard into the inside of the box (as a protective layer) which I have removed. I would like to fill these holes - what is the best way to do this?
If anyone is able to identify the wood, what would be a good finish to use on it? The box is going to be used as a valet box and will be kept indoors only.
In terms of repurposing it - the plan is to use MDF to create a tray/shelf which can be removed to reveal extra storage space - I'm not really confident enough to use wood to do this yet and figure I can remake it later on when my skills are better!
Any feedback is welcome!
Claus!
Claus!
