scooby
Firstly, hello all
I've been a time served joiner since I was 20 (I'm 30 now). Without meaning to sound big headed I became pretty good at grinding and honing my chisels & plane irons very quickly, mainly due to spending quite a bit of time in the joiner's shop during my apprenticeship. However, in my mid-twenties I went to uni for a few years to do a degree so I was only working part time. Hence I was using my chisel.s etc less and hence, sharpening them less.
Since I finished uni and went back to full time joinery work, I can't sharpen for toffee It's the grinding part that I'm struggling with, I use my dad's old Elu bench grinder and it is an unbelievable struggle to get a square, straight plane iron.
After all the struggle of grinding, honing on the warerstones is no problem.
So, I was considering (as an alternative to the bench grinder) getting a coarse waterstone (220 grit?) and a honing guide for reshaping and getting the primary bevel. Does this sound a feasible idea?
I normally don't agree with honing guides due to them resticting the use of the full stone, however just for coarse sharpening I think it would be preferable to a round bevel. Continue to hone free hand.
Does anyone reshape, removed nicks,etc by hand or should I just stop moaning and get back into the practice of free hand grinding and buy a different grinder.
I did attempt to make a jig for my dad's grinder but ended up giving up due to:
1. The grinder being quite small and the wheels are quite close to the bench (much closer than modern grinders).
2. Some of my chisels are very short.
Jon
Jon
