Hope you can help
I’m looking to make a garden table from a repurposed old kitchen table base and ex external door (see attached photo's).
The original kitchen table top is damaged and quite thin, so I’ll probably remove that first and then fix the door to the table base. Is this madness?
I’ll be adding some plastic feet to the bottom of the legs to keep the wood off the patio
Treatment wise what’s the best thing to try and make this last as long as possible ? I’ve used Yachting varnish on a garden bench that seemed to work well.
Ideally, I’d like to keep wood look for the base, but if need be I could prime it and use gloss exterior paint on it. Any suggestions?
