Thanks so much, I thought I'd ordered the wrong version then. L3 just gets left empty then. I'm gonna stand now instead of sitting cause I feel a weights been lifted off my shoulders.
You will probably find there are 3 inputs because the inverter is probably suitable for single or 3 phase input. Live to L1 and Neutral to L2, L3 blank. That is what my instructions say and mine looks the same make as yours (optidrive?).
It does seem like it might do more than just the purpose I bought it for. Yeah it's an optidrive e3. I've been watching videos of it on YouTube and apparently it can be set to run dc motors ! I'm almost tempted to try the old motor, just a little hesitant incase the 'motor expert ' cooked it by wiring it straight to 240v.
This new 3 phase motor is gonna take a considerable amount of fitting. The new mount holes kind of foul the old holes that have a tapped thread. I think the only way around it is to drill right through (even if it catches the old hole) and just bolt it on. It'll also need a new larger motor guard and the lathe cover attacking so the new motor can fit.
I wonder if the old motor would work. It'd still lack power, perhaps knacker the inverter if it is kaput.
I'll carry on with the 3 phase
It's quite a challenge for me to try and learn this, but I'm sure it'll be well worth it if I can. On taking the old electrics to bits I think I've figured out all the safety switches (belt door open,chuck guard open etc) it almost looks like there wired in a ring and if any are open the circuit is broken. I was gonna do away with these but I think it might be easy enough to use them in the circuit (not between inverter and motor)
