mahking51
Hi All,
Just bought a new LN 2" A2 .095" thick iron and latest chipbreaker to retrofit to my lovely Record T5 to use for shooting and the b****y thing does not fit!
Well it does go in the hole but no way can I make the iron protrude without fouling the front of the mouth; pulling the frog right back does not work as I run out of adjustment on the wheel and also there is a 'step' in the body casting which just lifts the iron assembly away from the frog surface.
Have tried the LN iron with the old chipbreaker but still no go.
I would appreciate any help here before this expensive chunk of steel is
sent back.
Silly thing is the plane works quite well as standard but I thought I'd give it a treat and fit the best iron etc.
Does not help that I got nailed over £12 for ParcelFarce and VAT :evil:
Regards,
Martin
sent back.
Regards,
Martin
