I’ve been researching like many others efficient ways of reducing heating costs. Now, I might be wrong, but I stumbled across Part L of the Building Regs updated 15 June 2022. Building regs used to just be involved with new installation, but now they also appear to be mandatory for replacement boilers.
The updated regs specify that all replacement boilers MUST have a maximum water temperature for heating of 55C!! An assessment of the radiators, pipes etc as well as installing a weekly cycle heater of the hot water tank (if there is one) to kill legionella.
All traditional boiler heating systems run at say 80C which means that radiators will be significantly derated in their BTU when run on a cooler water temperature. Now if my maths are correct, a radiator running at say 50C above room temp with a 1000W output (3400BTU) has when running at only a 30C difference only an output of 510W or 1700BTU a reduction of 50% meaning you need a radiator with twice the output…..or simply put new radiators! (You might be lucky and the installer over sized the existing rads)
With reduced temperatures microbore which is very common to have been installed as it’s cheap (8 or 10mm pipes) may not be able to deliver sufficient water to supply the necessary BTU for the rads to dissipate in order to heat the room. That means the pipes might need replacing to increase the bore to say 15mm. (225% more water volume than a 10mm pipe)
So why the change, (my theory) well the maximum water temperature that’s been set is…….the working temperature for heat pumps (air or ground source). So basically it’s getting every house ready for heat pump heating…….the UK does not have sufficient generating capacity for all houses to use heat pumps!
So, if your thinking of getting your boiler changed, and the installer is doing the work according to the reg, you could well be in for a very nasty and very expensive shock. Now that’s a sneaky implementation of legislation that nobody seems to have picked up / shouted about. A lot of people just won’t be able to afford to have all the upgrades necessary.
