Routermonster
Hi all
I bought a new Stanley 9 1/2 block plane a couple of years ago, and I haven't used it much since. The casting is poorly finished - full of grinding marks. The sole isn't flat, and the sides aren't square either. So I've started to flatten it ....
The blade doesn't hold an edge for very long. It's also very crudely machined, and although I've made some atampts to flatten it and polish it, I've given up (or am I just being lazy?).
I see that Ray Iles is advertising replacement blades on ebay, either "D2 high alloy tool steel" or "01 high carbon steel". They're both reasonably priced. The question is, which is better?
Is it worth perservering with this plane? Your advice would be appreciated.
Frustrated Les
Frustrated Les
