Repairing old pine planks
chaoticbob
14 Nov 2012
Wirksworth
I've (perhaps unwisely) ripped up the plywood cladding from my bathroom floor to reveal the original boards. They're about 10 inches wide by 3/4 thick. Many are quite worm eaten from the top, but will be ok if flipped - some bits are beyond redemption though. I went to a salvage yard and they wanted £35 a square yard for reclaimed boards of this size which seemed a bit excessive to me, though maybe that's the going rate? Anyhow, I took an unwanted plank door in the cellar to pieces and after cleaning up the planks are a close match for size/colour/rusticness(sp?), but one has a large (2 inch - it's an old door!) keyhole cut in it. I'm wondering how I might plug it - first thought is to cut it out with a holesaw and turn a tapered plug from offcuts, whack it in and plane flush. Will that work for stability and appearance?
Probably not worth the candle I know, but this is how I learn stuff.
Rob.
As long as your patch isn't directly above a joist, there's plenty of space within the depth of the floor. So you could cut a patch square-edged and screw another, bigger piece of wood underneath it, to make sure it won't disappear when stepped on.
Thanks Andy, hadn't thought of a backing piece :oops: . That's what I'll do. I won't be able to get as good a fit for the patch as I could by boring/turning a plug, but it'll still be less incongruous than a 2.5in dia round patch.
Rob
When I've done patches (a bit smaller than yours) I've cut them as diamonds with the grain lined up.
I did some on this project
post948570.html#p948570
Yours might need to be a bit more structural.
