stuartpaul
I know this technically isn't woodwork (alright, - it isn't woodwork at all!) but it will be when I fit the new mantle etc.
SHMBO wants a log burner and I'm in the process of removing the old fireplace and beating out firebricks etc.
The resulting opening will need to be rendered to provide a suitable finish and I'm pretty sure that a lime based mix will be more appropriate that a cement one. The movement required from quite a hot burner will almost certainly crack cement I'd think.
I'm looking to use one part masonry mortar (already has lime added) with two each of fine and coarse sand.
Scratch coat about 12mm then a final coat on top (about 5mm).
Is this the best way or are there alternatives?
Stuart
Stuart
