OPJ
Hi guys,
I picked up a 10'x4' sheet of white Formica from Bristol Decorative Surfaces last week (only £34 including! - thanks, Andy :wink and, I've been able to work on the top for my new router table this weekend.
It was time using contact adhesive and, it went pretty well. But, as with most things I do, I've managed to glue all over the Formica on the face side. I reckon I could carefully scrape this away but does anyone have any other suggestions?
I have some Goo Gone from Axminster somewhere - will that work? There must be at least one person out there who's as messy as me...!
Secondly. After routing the recess for my router table plate, despite going to the effort of making the jig, it's about 2mm wider than the actual plate! :shock: Aside from making a new top :roll:, does anyone have any thoughts on how I can solve this?
This is the Tilgear aluminium plate, where the grub screws in each corner attract to magnets set in to the recess below. Even with the router in place, I can shift the plate with my hand. It may be that it would stay still anyway... I suppose the easiest answer is to fit scraps of Formica around the edges?
Thanks for all your help,
Olly.
Olly.
