Hi,
Ive added a MFT top from a workbench to to a frame I made which originally I was just going to add just the normal flat top, however I'm having a bit bother getting accessories, dogs, clamps etc as the holes are 19mm opposed to 20mm for which you can get a multitude of things.
I was going to buy a set of surface clamps, however the plugs (PVC) on the bottom that go into the holes are 20mm therefore I wasn't going to bother then thought about the possibility of removing 1mm to make them fit.
Any ideas?
Only thing I can think of is sanding them, however this may not be very accurate as I would like the get a tight fit if possible.
Are there any other methods I could try?
Any ideas?
