Rob Cheetham
I have just finshed laying my dpm and 50mm celotex board down on the concrete base floor and am now ready to lay the 22mm t&g chipboard. The space comes out at 16.2m2 and each board is 1.44m2. So in reality plus 10% should be 12..37 boards. I have bought 12 but im still feeling that I will need more if im not too lose the tongue or groove on some off my areas where I have to do cuts.
I have gone on my sketchup design and found that I will get 10 full boards down with staggered joints. Then be left with two 9cm full length strips, 5 other 38x60cm gaps and one 38x9cm gap
My question is once I have cut the boards down that give me the tongue and the groove in tact still then for the rest I was thinking cutting a 45 degree angle on both joins to act as the joint and then to make sure they glue tight I will put temperary wedges in the expansion gaps to make sure it they push it up tight and creates a tight strong joint.
Would this work or am I going to have to go out buy extra boards just so I have got the tongue and the groove,
I have a router table but I have heard that to get a cutter to cut the exact t&g profile would probably mean getting one speicially made. So that is out of the question.
Any advice would be greatly appreciated. Thanks
