transatlantic
Boom!
I was given one of these as a gift a while back and have only just got around to setting it up. And in doing so, have noticed that the white wheel is massively out of balance. I'm pretty sure its the wheel at fault as if I take it off (leaving the grey wheel on), there is no vibration. I've also swapped wheels/flanges between the sides, and the issue still only appears on the white wheel.
I've used the dressing tool to flatten the front, and now that runs true, but the main issue is the sides, when spinning it by hand, and placing something on the side of the wheel to track it, the gap expands and contracts by around 4mm
I'd ideally just send it back, but I don't have the receipt. I've contacted Record and am waiting on their reply, but I don't think they'll do anything to help.
So now I'm looking at getting a new wheel.
I've only found them in a few places, but I'm looking at around £35 plus PP
http://www.yandles.co.uk/mobile/record- ... sbg8/p5088
So am looking into cheaper alternatives. I don't want to sacrifice quality, so am thinking of just going with a normal 20mm width. so 200mm diameter, 20mm width, and 16mm bore.
Axminster only do a 15mm bore
I've found some from MachineMart, but they're only £8. So I'm guessing quality won't be great.
