Mikebart
I have the above machine and thought I saw a thread on here about having to adjust the upper rear bearing when lifting the guard up.
Not a major issue but RP just said you will have to adjust it each time you change the height, it looks like the guard and hence the bearing is not staying in contact with the blade.
Shimming the guide is possibly the answer, has anybody experienced this or solved it.
Many thanks.
Many thanks.
