johnd
Has anyone got any pics of RECORD 77 shoulder plane and does anyone know where I can buy a replacement plane for the 77?
82 quid is a bit steep for a 77a in the UK (the 77 has a fixed nose unlike the 77a which is removable). £30 to 50 is a better range. I would not pay £80 for anything less than a mint nickel plated example. If yours has no chips off the corners of the mouth then you have a real bargain - well done!Bean":is10cl04 said:WOW I picked one of those up for a tenner last year :shock:
Jarviser":3af47eko said:82 quid is a bit steep for a 77a in the UK (the 77 has a fixed nose unlike the 77a which is removable).
bugbear":2zawslmd said:In the beginning was the Record #77 with fixed nose.
Then there was the #77a with a removeable nose and adjustable mouth.
(a) The record rationalised their range and dropped the fixed nose model.
(b) The removable nose model was given the designation #77.
I don't the how the dates for (a) and (b) relate to each other, wether there was a lag, or what, but I assure you, you can find planes marked #77 with removable noses.
Old picture...the miter plane was sold ](*,)engineer one":1i6x6ugs said:mike no wonder you had to beat up the bear to get the maple and his
pizza, with all those bits of tln stuck in a drawer.
right hand side next to tln mitre plane i guess
but then have been known to be wrong ALL the time :lol: :lol:
i'll take a saw handle with my points :twisted: :twisted:
paul :wink:
Yeah, well an anti-gloat, really. The 98/99 pair, the L-R 95 pair and the miter plane are gone. As are the LN spoke shaves. And the small LN chisel plane.Philly":2taanfza said:Mike-now that is a totally un-necessary gloat.
Fun though! :lol:
Philly
Who's been known to get the occasional gloat in......
Assuming Harrison has it right, which is apparently a dangerous assumption to make but until John Horobin stops playing with cacti and gets out a book on the subject we haven't many options, but assuming it's right:bugbear":xmt7evas said:In the beginning was the Record #77 with fixed nose.
Cheers, Alf076, 077 and 077A Bullnose planes:- Early examples of these planes had a small triangular shaped panel recess on each side of the plance which had a chequered pattern cast in it. However this feature doesn't appear in any catalogue photographs which always show the planes with flat machined sides. Later models appear as depicted in the catalogues. Early 076 lever caps had RECORD BRITISH cast in the top and highlighted in orange paint on the blue enamel. The 077 and 077A had the same words high-cast into the top of the lever cap. In 1969 the lever cap of the 076 and 077A had been redesigned with a more modern profile and no name cast into it.
