Glynne
I've been watching Cheerup347's posts about bandsaw issues but I have a slightly different one.
I initially set up my bandsaw with a 1/2" x 6tpi balde from Tuffsaws. I aligned the fence using a manual cut to a parallel edge and then adjusting the fence to the actual cut (normal practice). The fence was a few degrees out from the mitre slot and this was down to the table not being tightened down which I corrected. All subsequent cuts were fine.
Yesterday I needed to do some resawing so I swapped the blade for a 3/4" x 3/4 vari tpi blade (again Tuffsaws). In checking the fence position, the actual saw blade was "twisted" to about 15 degrees to the mitre slots. When running the saw, the blade tracks perfectly in the centre of both wheels but runs at this strange angle? I didn't try and adjust the fence to this angle (not sure that it would adjust that far) but used a point guide instead. Apart from initially having too much tension on the blade, I managed to resaw 8" boards quite comfortably and accurately, albeit at a strange angle to the table mitre slots. Altering the tracking using the top wheel had some minor effect but nothing like as much as needed. The guides weren't interfering with the blade either.
Today I swapped back to the 1/2" blade and and this blade runs in the normal plane with the adjusted fence being parallel to the mitre slots.
Whilst I have no immediate plans to cut any veneers, I would like to be able to resaw using the fence and so I'm at a loss as to what is happening or what I'm doing wrong? I haven't done a co-planar check but I wouldn't have thought that the blades would track if this was out?
Does anyone have any suggestions please?
Thanks,
Glynne
Thanks,
Glynne
