RogerS
Any recommendations as to a suitable product to extend wi-fi coverage out into the garden, please ?
TIA
TIA
Is that an outdoor unit. I have 4ft thick walls for the internal mesh network to penetrate !How far out Roger? I recently got the BT Wholehome mesh network system and the signal reaches the bottom of our garden which is about 100ft.
Did you use the Omada software to set it up ?I installed a tp-link EAP225 this year. Very easy to install and configure, gives complete coverage over a huge range as it's mostly direct line of sight. I can now mow our 2 acre meadow and listen to streamed audio at the same time.
Oh that's really kind of you, thanks. I'll pull something together.+1 for ubiquity. It’s not about how powerful an access point is but rather what kind of a “heat map” it gives. For example most consumer grade access points will give a reasonably even spectrum 360 degrees around it. This is fine for most people, however sometimes you need to target your heat map a bit more. Ubiquity access points provide both. It’s get pretty technical but this is what I do for a day job . If you pm me a few details such as a quick sketch of what your are trying to achieve I can def help.
