Zeddedhed":1w7po5uy said:CStanford":1w7po5uy said:The edge of the knife actually shouldn't be perfectly parallel to the stock. See Robt. Wearing et al.
Not having any idea what Robt. Wearing et al refers too would you care to expand on that please?
custard":3alu6w89 said:The theory is that if the knife is slightly skewed it pulls the stock against the workpiece. Maybe, but it also cuts a thicker gauge line which might not be a price you're willing to pay. Like everything in woodwork, worth considering but don't take it as gospel as it all depends on the woods you work and the work you do.
Almost the only line anywhere which needs cutting (with a gauge) is the base line of DTs, IMHO.CStanford":1sr18a3s said:...
For marking mortises all you need is the faint line produced by the traditional pin gauge. You do not need, or particularly want in my opinion, incised lines in the length of the grain. The only lines that needs to be incised are the cross grain lines at mortise top and bottom. ....
Jacob":2juqg3th said:Though there are variations of the Marples pattern e.g. slide instead of turn-screw, which makes it cheaper.
Cheshirechappie":1p7zjg23 said:Just a small tip for anybody with a newish screw-adjustable mortice gauge. Mine (mid 1980s vintage) was very stiff to operate when adjusting the gap between pins. Stripping it down revealed that the little spring-clip (or spring-washer) holding the screw into the lump at the end of the brass slide-rod made the turning action of the screw very tight. Easing the clip off a tiny bit with a screw-driver tip loosened it up just nicely, and the whole tool worked beautifully once reassembled. (I think older gauges had a different method of retaining the screw, so that won't apply to vintage models.)
Another tip is that new ones sometimes have pins that are not exactly at the same protrusion from the stock, so the gauge marks one heavy line and one barely a scratch. It's worth a bit of work with a small, fine file to get them same height, and as others have said above, shaping the pins to tiny round-ended knives helps a bit, too.
Zeddedhed":2uhbnnyh said:Just done it to mine and it's now so smooth it operates from voice commands only!! I rubbed on a bit of candle wax as well just 'cos.....
David C":9jcb1ju1 said:Zeddehed,
The round hole is a nasty, modern, cost cutting perversion. I think I would look for an old gauge or cut a new opening for a square section wedge.
David Charlesworth
