leisurefix
I have been looking and struggling to find a decent solution for power sanding the inside of deep undercut bowls, imagine a 5 to 6" diameter slightly ball shaped bowl that is undercut. I use a Bosch drill with 2" Simon Hope arbors, which are great, but will not fit I side the bowl to do the undercut parts. I have a 12v Bosch cordless drill driver with right angle attachment, the tool itself is excellent, but not for sanding. Trigger is tiring to hold, and speed is slightly too slow, and batteries wear out fairly quick.
Have considered variable speed angle grinder, but min speed is 2800rpm which i think may be too fast. Have also looked at Makita Da3010 angle drill, but it is £200 (if it is the best option then will accept the cost). There is also the proxxon long neck angle grinder, or polisher which are similar tools, just different speeds. Lastly there is the King Arthur Merlin2, but that seems more suited to sculpting than sanding.
Does anyone have experience of using these and would recommend them, or any other options.
Thanks in advance,
Andy
Thanks in advance,
Andy
