Wuffles":1557v001 said:You know you're posting this in a metalwork sub forum of a woodworking forum? Just in case you'd forgotten your current audience
Sent from my iPad using Tapatalk
matt scarlett":2v62uin1 said:I see people using woodcutting tools for cutting various metals, table saw, routers etc. What say you?
Wuffles":qvs1iwfi said:You've possibly seen aluminium being cut and milled.
matt scarlett":3e4yljht said:Wuffles":3e4yljht said:You've possibly seen aluminium being cut and milled.
Yeah, but even with that, there are plenty of sparks, as one might expect. I could design and build my own speaker terminals, maybe not a fancy SF design
But it would be nice to design my own terminal plates
I'm certain of the basic tools needed for woodwork (not brands), because I've done it before. Metalwork is a mystery to me. Or would it be cheaper to outsource the work?
Absolutely correct, my mis-reading, very many apologies from me. That mis-understanding makes the rest of my post irrelevent of course. xymatt scarlett":2zw95bsp said:xy mosian":2zw95bsp said:Hi, I spent more than a decade in the Acoustics Lab, Loudspeaker design really, of a well known, and in some areas respected manufacturer of HI-Fi loudspeakers.
My work included the testing of both speakers we were developing, units and systems, and some of those of other makers. The upkeep of the test gear was included in that.
Later I moved on to Tweeter design with Horn, sorry wave guide, loading, and latterly the development of a very nice flat field unit. I would say that wouldn't I?
I see from the link, https://transmissionlinedesigns.wordpress.com/, that the site author recommends design by listening. There is nothing wrong with that, to my mind, plenty of reasonable loudspeakers have been designed that way.
Audible testing is quite possible using a Pink Noise signal and in looking for a link to such a signal I came across this site http://www.audiocheck.net/testtones_pinknoise.php. A good place to lose any amount of time, for me at least.
I would recommend that you download a pink noise recording and then get used to listening to it. Play it on all your reproduction equipment, bearing in mind that everything between the file on the server and your ears may change the sound.
Play, sorry experiment, with the graphic equalizer of your PC audio player to get used to hearing the effects of louder, or quieter, frequency ranges. Then listen to your newly developed system how is the overall balance? Are there any bands of frequency missing? This last test is perhaps best done with one speaker, it saves building two anyway. Then, for car speakers, listen again in the car.
I should say that I know little about car systems other than the fact that most around here only have a one note Bass.
Last thing - Go For IT
Hope this helps,
xy
https://transmissionlinedesigns.wordpre ... isclaimer/
The site author is me, and to make a small correction to your comment, nowhere in the article do i advocate design by listening!
(https://transmissionlinedesigns.wordpre ... surements/) What i'm trying to get across is that at some point we have to put the measuring equipment away, and our ears take over. One builds speakers to listen to, and no=one has an inbuilt measuring device for listening. We do it by subjective listening devices.
It has been my experience of nearly 3 decades of exposure to a vast number of audio products (as most of us have), that regardless of such engineering endeavors, I have experienced;
– Good and bad products at all price levels. Under the category of bad, I also Include aspects such as build quality.
– Good and bad (to my ears) sealed or open (ported, bandpass, transmission line etc) enclosure designs
– I have been impressed by some, and very unimpressed by other audio products that have displayed the idyllic graph responses, quoted specifications or T/S (Thiele/Small) parameters.
– Mostly unimpressed by published Hi-Fi magazines ‘5 Star’ recommendations.
For every theory and aspect of design, you'll get a design that will ignore such a theory and still sound impressive to the ear. Diffraction for example, opposing driver to help with cabinet resonances, for another example. although i haven't worked in the design field professionally, i have some some installation work,. The last i semi-helped with was a near £300k McIntosh based system. We swapped some of the Kimber cables (near £16k worth if my memory serves right) for a set up of around £200-300. Could the customer tell the difference? No!
