Rate this bandsaw?
Loz I only know about bandsaws from my short experience with my own. I think that if the depth of cut is within the limits of your future work then this saw will be okay. First think i would do with most new bandsaws is buy a GOOD new blade. Most bandsaws come with a substandard blade.
If it was me i bought my first bands about the same price as the one you have highlighted. I found that very quickly i felt that i should have went for a saw with a deeper cut. Keep this in mind. I like the Axminster saws around £250 mark, but this might be more than you want to spend.
Hope this helps a bit and good luck.
Loz,Is you buy that saw you are confined to 3" dept of cut maybe ok for Pen blanks?? Im not sure even of that . If this suits you I have one stacked away somewhere in perfect working order which you can have for nothing. REgards Boysie.
Oh bugger - im getting my throat and height mixed up - its only 80 high !
Ok - ill keep searching !
Boysie, Your very generous, a very rare trait in this day, but i think ill try for something bigger !
I just dont want to spend 300 euros !!!
Loz
Plus Loz, motor is only 250 watt.... bit on the 'light' side..
there'll Be more 'grunt' in your elbow and a bushman :wink:
I'm fancying a Bandsaw myself.. and a decent pillar drill.
but then, I fancy an Aston Martin DB9 too....
:p :p :p :p
Oh well, the DB9 will just have to wait till next month :p :p :p :p :p
I know what you mean Jenx,
I was at the Club Chairmans ( and my tutor ) place last week. He has a massive Scheppagh ( ? ) band saw - 2 hp motor i think he said ! must have been a 18 inch cutting height.
and his lathe - jez - Vicmarc 300 - i fell in love !
heh heh... :D
be lovely to have an 'inexhaustable tools fund' wouldn't it ?
I'm sure you'll be the same as me ... there are these other people who occupy my house, that keep insisting on 'clothes / shoes / getting fed / new curtains / PS3 Games / nights out / needing money for their girlfriend's third cousin's neighbour's cat's vet bill / .......
Don't these people REALISE that a man has a 'primaeval need for powertools' ?
:p :p :p :p :p
Nappies / Babie food / Ballet classes ! / And now the leckie bill is in !
Turn that light off !!!!
Loz&Jenx Lifes a beech :oops: aint it been there and all that, and when all the hardship is over :lol: :lol: along comes the Grandchildren and will you look after them for the weekend Pleeeeeze and then the Grand Childrens Children and the the circle goes on and on . I dont know how She sticks it at all. SHED is out of bounds :lol: :lol: :lol:
loz":kk7z5yzp said:
OK,
Wife is tralling ebay now for a larger saw,
However i have been youtubing looking for instructional videos, however think i will buy Alan Holthams bandsaw dvd.
While i was looking though i found this -
http://www.youtube.com/watch?v=YXW55S4X9zo&feature=related
amazing.
That Adam Sandoval is a VERY SCARY MAN :shock: :shock: :p
I can just see it now,.. me thinking ' och aye, I could dae that, nae bother' ... only 45 minutes before being rushed into A&E, with mangled bleeding stumps, where my hands used to be.
:p :p :p :p
Amazing is right enough ! great vid, Loz. :wink:
heh heh, Boysie... my 'brats' are now 23 and 18, and are worse than they ever were as 'bairns' ...
and as for the 'Ayatollah' herself... :roll: :roll: :roll:
:wink: :p :p :p :p :p
you can get a baby fox bandsaw from axminster new for less than that ( ithink they are 99 notes) - I bought a rexon version (of which the fox is a virtual clone) off blister last year and for cutting blanks round I reckon its the dogs danglies
its not got loads of power (350W) but it will happily cut a 3" oak blank which is all i need.
Lots of people will tell you to buy the best / biggest you can and spend lots of wonga but personally I'd say buy what you need - and if you only need a little one buy one of those - its not how big it is that counts but how well you use it afterall.
quick correction -as clicking the edit seems to be causing my computer to freeze - i of course meant a baby jet bandsaw not fox - doh
and its 97.99 ex vat
I tend to disagree with BSM.
If your only going to cut blanks for small items less than 3" thick, then fine buy a bandsaw that will do that.
BUT if like most of us who try and use raw wet timber which you pick up in all shapes and sizes, then I would suggest you get the biggest (within reason) which you can afford.
I get most of my wood supplies as freshly felled logs. I start with the chainsaw to convert it to usable sized pieces, but often I have to re-saw it which is when the height of cut comes in. IME the throat size is less a need for turners, than the height of cut. This is only if you want to re-saw. If you plan on buying blanks ready prepared the whole question of size becomes irrelevant.
I have a 8.25" height of cut bandsaw, and many the time I have wished for a bigger cut as at the minute I am restricted to 8" bowl blanks unless I break out a chainsaw.
I don't think I will buy a bigger bandsaw though, simply because once you go above a 8" height cut the price increases something silly.
You really need to think about what you intend doing as your hobby progresses, then try and purchase what you think will do the job.
Well thanks for the advice guys,
Gonna cost up and see what i can afford, but i certainly don't one to be buying a new bigger one in a few months time ( im already thinking about the lathe upgrade also ! )
Loz
each to their own mate - but Ive got round the throat issue by building a false table outside of the blade , with a sliding pivot point built in (as if you are cutting rounds you wouldnt be using the fence anyway. I routinely cut 18inch circle by the simple expedient of knocking the corners off with the chainsaw first.
in terms of depth of cut my little rexon will do 6" max - though it is happier with 4" but as i'm mainly doing bowls/clocks/platters etc it is rare for me to want more than 4" depth anyway - on the rare occasions that i do need a deeper round blank I knock it to an octagon with a chainsaw then rough it between centres.
I'm not saying dont buy a deep cutting bansaw if you need one , but dont buy one just because you want to look like a pro if all you need is a more modest cut.
Hi BSM. Think you picked up the wrong idea from my post. My comment was about RE-SAWING timber. ie; creating blanks from wet logs and so on. Great if you have a chainsaw, but if not you really need the biggest bandsaw you can afford.
I don't understand your comment about the throat, as I said to my mind the throat of a saw is really immaterial to most turners, it's the height of cut that counts. If re-sawing.
fair point - being a countryside profesional i tend to forget that not everyone has as easy access to chainsaws as I do. That said i'd still say that if you are going to do a lot of resawing you'd be better off spending your money on a small bandsaw and a chainsaw (plus safety kit) rather than on a monster bandsaw alone - for one thing having a c/saw allows you to mill wood in the field and leave the waste there.
what i was saying about the throat is that I'm rotating the blank outside the blade - ie on the side away from the saw body , not between the blade and the body of the saw.
anyway lets not argue - as i said each to their own.
