Anyone use one of these regularly or have it as their main user?
I recently picked up one for a snip as part of the same job lot the marking gauge without a locking mechanism was in:
The plan was to sell the two smaller ones on after sprucing them up a bit but testing the Rapid I discovered it works really well, much better than I would have expected for a single-pinion drill. It isn't the quietest but drills comfortably at the maximum diameter the chuck will take, about 6mm / 1/4", something not a few larger drills I've had won't. The jaws will also grip bits down below 0.5mm making it a cracking little user. Well chuffed for less than €1!
Here it is after a bit of TLC:
