Rake and Fleam guide
I’ve had a couple of my dad’s old saws in the garage for a long time and recently decided I’d like to try to sharpen and use them. I bought a few saw files from Axminster, got a cheap Eclipse 77 saw set and a test saw for my first experiments on ebay and built myself a saw vice.
Unfortunately I was already down this road before I read Alf’s very relevant note at:
http://www.ukworkshop.co.uk/forums/so-you-want-to-get-into-using-old-saws-t11720.html
I had read a lot of the saw sharpening stuff on the web and had made the rake guide blocks described by Pete Taran (http://www.vintagesaws.com/library/primer/sharp.html available at the wayback machine archive at web.archive.org).
Then I saw Bugbear’s rake angle control guide at
https://web.archive.org/web/20050406115524/http://www.geocities.com/plybench/shop_projects.html
which looked a lot easier to use on a cross cut saw.
I’ve made a couple of small changes. Instead of a wooden file collar I used a 12mm diameter depth stop as the collar on a 12mm dowel file handle (a 12mm drill depth stop would do as well). The fixing screw is standard M4 so I used a long bolt as the vertical indicator.
With a couple of nuts locked together half way up this and a wing nut below I can fix a horizontal fleam (bevel) guide.
Cost, a few pence. Veritas do a commercial file holder at £ 41 but I couldn’t justify spending that much.
The parts, just a drill stop to fit the dowel file handle.
Easy to use for both rake and fleam control.
Regards
Jim
Regards
Jim
