Done a bit of work on the car boot Stanley No 6 Type 9. Just cleaned off the worst of the rust with citric acid and tried, unsuccessfully, to get the overspray and other paint off the handles without wrecking the original finish. Iron is quite badly pitted non-original UK Stanley and lever cap is beyond salvation. Sole seems to be pretty flat, and swapping lever cap and sharp bits from its twin suggests it'd be a good user. BUT, a contemporary lever cap is about £20 on line, which sounds uncomfortably close to the going rate of about £50 for this model on that well-known auction site.
Some pics of salient bits below:-
So.. will probably just try to find any old lever cap to fit and repair the rear handle with some rosewood from the stash. Question - would you plane off the break to give a single gluing surface, or flatten the two existing break surfaces and fit separate pieces. My guess is the former, but worth asking. Hadn't spotted until looking at the pics that at some stage, the spur probably got broken. Someone then tried to nail it back on (!) and in the process split off the side piece.
