YorkshireMartin
Hi all.
I'm getting a bit of scalloping on the innermost mortice side (the edge furthest away when facing the machine). I've narrowed the problem down to chisel alignment. I'm using a 1.3/16" chisel so no bushing is installed. 20mm chisel is Japanese made and Japanese pattern from axminster and as far as I can tell, is straight and true. The machine has a jacobs chuck.
When installing the chisel, I encounter a problem when I nip up the retaining screw. Essentially, there is a slight clearance between the chisel and it's mount, so tightening it is bringing the tip of the chisel forward ever so slightly, approx 1mm, exposing the auger on the far side, thus creating the scalloping which is about 0.5mm deep.
I just wondered if there was a bushing of any sort for the 1.3/16" chisels? If not, has anyone else experienced this problem and overcome it? I thought of perhaps using a shim made from a coke can if it will fit.
I'd leave it except that it causes the bit to chatter against the chisel from time to time (this may be normal?) and also for through mortising, the finish will be affected.
I'd appreciate any input.
Many thanks.
Many thanks.
