I've been thinking about buying a dust commander cyclone and some sort of bucket or barrel. I have a SIP 01929 extractor (the 50ltr metal drum type) which I don't use. So before I spend money I thought I'd have a go using it as a separator and see how it does.
After removing the motor I managed to find enough adaptors and pipes to make things fit. I bolted a bit of ply on the top with some underlay as a gasket and the suction was still very strong. With the inlet and outlet connections just straight, it took about 75-80% of the sawdust/chips.
I added a bend to both, the inlet pointing to the side wall and the outlet just directed away to the other side of the drum. That made a big difference, reducing what got to the actual vac to about 3% at most.
I'm thinking it might be worth doing some sort of thien baffle separator design inside it. I don't really know how that would improve things but I hear it will. Any suggestions welcome.
Anyway, 15minutes and zero cost so I'm pretty happy with it so far. The aim is to make my filter cartridge last longer and maybe start using bags again.
Here's the vac (Trend T30) and the converted SIP.
This is a comparison of a test clean up. Vac first.
and the separator showing it got most of it..
and a pic of my rough and ready plumbing.. The directions of these seemed to really help.
Cheers,
Carl.
Cheers,
Carl.
