Hey all,
I'm new to the forum, despite being a long-time lurker. I'm hoping you guys can help steer me in the right direction. I'm getting back into woodworking after a dalliance a decade ago. I have a small, single internal garage (8' x 16' approx.) that has never had, and will never likely have, a car in it.
I intend to use mostly handtools with a bandsaw perhaps eventually being the only machine. As per the photo below, it's block construction with a course of bricks on the outside of the cavity. It has a flat concrete floor. Above it is an unpopulated guest room.
The questions I'm looking to solve are:
1. If I batten and insulate this, should I leave all the wiring on the outside in trunking? If not, how do I handle the wiring with regards to the insulation -- is it okay to cover it? Are there specific methods for this?
2. What would be the best boarding and insulation materials? My initial thought was a Rockwool kind of insulation covered with plasterboard. But then I considered Kingspan/polystyrene covered with OSB. Is there a consensus on the right way to do this while keeping the budget as low as possible?
3. What kind of lighting would you suggest? Given the small space, I presumably don't need much but wasn't sure if I should go for overhead strip lights, or have specific lighting for the main working areas.
4. Should I insulate the floor? I think it could help in the winter, but not sure if my assumption would make much of a difference.
Your thoughts and ideas are greatly appreciated!
