A
Anonymous
Guest
Hello Mike
Can you please explain a little about how saws were put ogether in the factorys years ago, specifically fitting handle to blade??
I have stripped down, cleaned, reassembled, set and re-sharpened perhaps 2 1/2 dozen saws. Even on saws of the same make and era I've noticed that the holes never seem to match up from one saw to another (near impossible to swap handles), which suggests they were sort of "hand assembled" as one offs?? Were the holes drilled or punched into the metal and then it used as a guide to drill the wood (as per your sequence) or was the wood drilled first, blade inserted into correct position and then the blade hols punched or drilled through the existing wood holes using THEM as a guide?? Or was there another way?? I am just curious :lol: Cheers Mr Spanton
