Question for Electricians
Ozi
26 Dec 2020
Rugby Uk
I'm just starting to renovate a house and have an electrician coming over next week to do basic safety checks and fit a bathroom extractor. I want it on a humidity sensor and independent of the lights. He has asked if there is an existing fan (easy answer no) but there may have been one, there is a vent on the outside wall which may at one time have connected to a fan above the shower. Loft access is really tricky, it's a very low pitched roof on a rear extension, it will take a younger man than me to get in. BUT there is this unknown switch which might once have connected to a fan, it's not your normal light switch but there my expertise ends
Short question - what do you think this is
Whats the other side look like? Hopefully it is obsolete with no power present because it looks like there are no wires to the earth terminal.
Looks like a triple pole fan isolator switch to me, defo if it only has one rocker on the front.
The colours are the old 3 phase standard for wires. So, if it’s a single switch keep your fingers out! If it’s 3 phase, it won’t ask twice, it will just kill you.
More likely to be old two way switching, surely? Keeping your digits out is sound advice, whatever.
Could be an old farm where 3 phase is common, or a converted industrial building a barn, could be anything!
Can't see it being 3 phase, just standard old 3 core cable colours, commonly used in 2 way lighting circuits.
If it is a triple pole isolator switch, it will have a permanent live (so will need to be isolated elsewhere) used for the fan overrun/timer, a switched live from the actual local switch to turn the fan on and off, and obviously a neutral, all standard configurations for an extractor fan.
