I made some blades from ground flat stock. After quenching in oil and tempering, some had a sort of round bubble marks on them.
This one is 13mm wide and the marks are raised:
This one is 11mm wide but the marks are much more faint and not raised:
I've read that the marks are caused by the steel getting too hot. I've sharpen the narrower blade and it's really sharp (cuts paper). but will it be too brittle to use as a plane iron?
