Graham Orm
Any ideas? It's not particularly thin, but it's coming through as black dirty marks that won't sand off. I've had to remove it all. What glue can I use as an alternative to PVA for veneering?
Droogs":23xzv1ch said:After having had similar probs in the past, I now use hide glue as it doesn't matter if theres any bleed through as I hammer veneer for the most part and it's spread on both side during the layup process. Once dry then scraped off, it also doesn't react with finishes so is ideal for me. Does have a short working time but all you need do is heat it with a hot clothes iron to soften the glue and continue working.
HTH
Droogs
Woodmonkey":2mv64a64 said:Cascamite
Graham Orm":18bvxn36 said:Any ideas? It's not particularly thin, but it's coming through as black dirty marks that won't sand off. I've had to remove it all. What glue can I use as an alternative to PVA for veneering?
Beau":2g6w6r24 said:Graham Orm":2g6w6r24 said:Any ideas? It's not particularly thin, but it's coming through as black dirty marks that won't sand off. I've had to remove it all. What glue can I use as an alternative to PVA for veneering?
Have you any ideas why it's coming through as black?
Used PVA with maple veneers before and had it bleed through in the vacuum press but it's comes through PVA coloured which is normally white and invisible once dry and cleaned off. Can't see why other glues would be less likely to bleed through.
RobinBHM":1zv0f25x said:I believe UF with resin hardener is often used for veneering
http://www.gluesdirect.co.uk/catalog/in ... th=204_206
Adam9453":1si99315 said:i've got titebond cold press veneering glue which is supposed to be very good, although I haven't actually tried it yet.
got the veneer, got the glue, now just need to buy some time!!!
Graham Orm":sn7djj0a said:Thanks Adam, Found it!
PAC1":193m6azf said:Graham, I am delighted you have resolved the problem but for my education could you explain the cause of the black marks and the solution?
Graham Orm":1f5iwikl said:Woodmonkey":1f5iwikl said:Cascamite
Thank you ;-) I'll track some down. Have you used it personally for veneering?
Woodmonkey":24kpvytu said:Graham Orm":24kpvytu said:Woodmonkey":24kpvytu said:Cascamite
Yep used it several times with no issues. It's got a nice long open time too which can be useful on more complicated jobs
