I'm slightly reticent to entering this conversation (!) coming from a desire to fit such a system but no practical knowledge. Locic sasys to me plastic drain pipe as all fittings are immediately available at the local plumbers outlet, and how ever carefully you design something an immediate back up of parts is worth quite a lot of money.
I can understand the bare copper wire down the plastic pipe conducting away the electrostatic charge, but how do you get the wire out to earth it? Having just written that I realise a small hole at some point and silicone to seal it, or a 4mm bolt with earth tags inside and out.
But then I have difficulty with the option of placing of aluminium tape on the outside of the pipe - could I ask if Sunnybob could continue his discourse on static electricity to explain how the charge generated inside a plastic pipe gets to the outside, and further, referencing this tape, how it works when it will have an adhesive layer and possibly a plastic layer before you get to the conductive film on the surface.
Rob
Editted to say this is now an out of date request as I'm reading the article from Wood Central!!
Rob
