Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
(Click the image to see the album on Flickr; scroll down on this page for details and price)
This is the older version of Axminster's 2-axis, hobby morticer.
NOW PRICE REDUCED: I want £200. I can't go any lower than this - it's worth more to me to keep (apart from spouse pressure to rationalize!).
Cash on collection from BS9: sorry, I won't ship it (it weighs more than 42kg!) but you can try it out here if you want, before deciding.
A new-spec one is presently £295, but I am including about £150-worth of accessories, so it's ready to go on carcase work and even house-sized doors (with care!).
It has a complete set of accessories:
There is slight surface rust on some components, but nothing serious (see the pics). All slideways, gib strips, etc. are well greased/oiled and rust free. It's also pretty clean and the gas strut is fine!
Note: The yellow/brown staining on the paintwork (in the pictures) is NOT rust! It's remnants of the heavy grease it was covered in for shipping. As I said, inspect thoroughly and try before you buy - you'll see what I mean.
I have made a casement, entire window frames and outdoor furniture with this, and I think it's brilliant. The two-axis table makes precise alignment very easy, and coupled with a bandsaw tenon cutting depth stop, the M+T task becomes fast and relatively easy.
If it doesn't sell here, it will be advertised locally. I won't be putting it on eBay, but there are a couple there now if you want to compare value...
- Set of three chisels and augers in a box 1/4", 3/8" 1/2" TiN-plated. 1/4" and 1/2" are not used apart from a test of the 1/2" one. The metric equivalents are around £67 new from Axminster #947751 (but the new ones are prob. better quality).
- Extra 3/8" chisel+Japanese-pattern auger well used but very sharp. The Japanese pattern auger seems to work better than the European ones in the TiN set.
- Sharpening kit with diamond plate. Wicked sharpness can be yours! (now £51 from Axminster, #700173).
- Drill adaptor (£25 from Axminster, #400287). This is also well used (well-useful, innit!), the chuck scroll is worn - still good for general jobs, but a new one would probably be more precise.
- Riser block kit (£8.50 from Axminster #950175). Useful for deep stock, but awkward to fit single-handed.
- The correct, extra-length chuck key for the auger chuck (also fits the drill chuck)
- A set of Allen keys for the various sizes on the machine (I have replaced the Bristol levers with stainless Allen bolts for the adjustments)
- Setup tool from HM Royal Mint, complete with retention system (£0.02, widely available). Fishing line available separately.
