Project CozyWorkshop + sawmill visit
Boz62
9 Dec 2008
West Oxon
Right, I'm nearly at 50 posts, and have had my first whinge about lack of photies :). So I thought I'd better set up a photo hosting account and show progress on this Spring's task - Project CozyWorkshop.
Some background to start with. I live in a diddy 1960's bungalow, with a single garage and postage stamp lawns. When I moved in 22 years ago it had a lounge extension, which luckily also added a few feet to the garage :). Sadly this also created a 20mm step in the middle of the concrete floor :(.
I originally setup the workshop for car maintanance and DIY. This explains the distinct engineering bias to the workbench. This was the outside wall side (click on the thumbnail for a larger image)
Some old french doors sealed off the garage end, with my old 1930's Myford ML2 lathe taking up the other wall adjacent to my lounge.
Now I'm getting into woody stuff, I decided to extend and insulate the workshop part of the garage so I could work out there in the winter, keep the noise down for the neighbours and store more tools out there. I wanted to keep the car in the garage - I couldn't afford to insulate the whole garage, and I like the idea of always having a car sized empty space to work in - just back the car out and unfold the layout table. It also means a smaller volume to heat for everyday use :). The old workbench was destroyed (sniff), after some tests with a temporary deadman. This was to work out how they work for my inevitable followup project. Rusty Dexion runners didn't help :(
First task was to empty the workshop into the garage. Another advantage of usually keeping the car in the garage, emptying it to make space was very easy. Leaving just enough space to lay down 2.4x1.2 sheets on battens for cutting up by circular saw.
I then had the remaining part of the original garage end wall to cope with. This was cut shorter, leaving a buttress of suitable size (as per building regs).
This is when I have to give thanks to Mike Garnham for all the wise words on insulation and condensation. I chose to use battens and 2" rockwool batts, with 11mm OSB lining. I decided to use a vapour block liner for this wall and the ceiling to save sealing the OSB sheets to each other. These are only screwed in place, so if I really need to get behind them I just unscrew - in theory. Battens were screwed to the reconstituted stone wall (very hard stuff) with Spax RA anchors. These were a revelation, they made battening very very easy and accurate. The wall on the house side was left plain, to gain some heat leak 8).
The flat roof is far too low but I'm stuck with it. Height is severely limited. So I decided to use only 6mm ply for the ceiling with 3" rockwool batts (with vent space above) friction fitted. I used a vapour block again. Due to the far from level roof joists, the 6mm ply was great for following the curves. It was a right b***** to get up there single handed. By the third sheet I had it sorted - but wish I'd known all that for the first sheet!
Once the new partition wall (2" battens, 11mm OSB each side and 2" rockwool again) was screwed in place, emulsion was splatted all over the place. Then the floor of MR T&G chipboard was laid. Half was on variable thickness battens, 5 - 18mm, to suit the far from level floor, rockwool in between, with grey 3mm closed cell concertina flooring foam on top. For the original garage part of the floor, which was much more level, I just used the 3mm foam. No vapour barrier - the foam is meant to do that, and the concrete was shown to be dry anyway (thanks again Mike!). In an ideal world I'd have used a leveler, and 2" or more battens, but ceiling height didn't allow it. The floor was finished with Leyland floor paint in "Frigate". Otherwise known as light grey. This seems so far to be adequate. Went on very easily, but the 7 days for it to fully harden was very frustrating. Lights are 2 x 5' single tube HF fluorescents by Sylvania courtesy of Screwfix with daylight tubes. These are fitted out to the sides to light the work areas and keep ceiling height clear in the centre. They seem a bit cheap and flimsy, but have already happily taken a few bashes - inevitable with a low ceiling :oops:
A simple but strong internal door was made, well insulated, draught exclusion fitted, solid bolts and hinges fitted. Up and over doors (on the garage end) are a little vulnerable so I've tried to make this wall secure to help me keep my tools. Then stuff was moved back in. I'm still at the "bung it in a crate" stage, hence the piles. Future jobs are some shelf units and cupboards. I'll be fitting french cleats along all the walls and making "modular" units so I can move then around to suit.
So, here it is as it is now, with the bandsaw, and the dust extraction propped against the window :).
And here's the view from the outside "back" door. With ML2 lathe, crummy Wickes pillar drill, and the folding wooden layout table pressed into temporary use as a bench of sorts. The green sucker bottom left is latest new toy - a Camvac 286 to go with my new Trend Airace (gloat over). This project really highlighted my need to control dust. I got quite ill at one point from a day of cutting up OSB with my circular saw. After that the Trend was bought and removed that issue. And I've now broken the old Electrolux that had done dust extraction duty (badly) for the last few years, which was a good excuse to get the Camvac to get hand tool and bandsaw extraction with decent filtering and a bit more reliability.
I now have a space 2.4m wide and 2.8m long and 2.0m high, which isn't much compared to some of your workshops, but it feels like luxury to me :). And I can always lay stuff out in the garage end if it isn't too cold. Thanks to all those who I've learnt from on here before I decided to tackle this - I was a lurker here long before I joined :D
Boz
[Edited to correct sheet size]
[Edited to embed thumbnails and link to a different route to the photo to get around Fotopic probs]
Looking good Boz! Do yourself a favour and get rid of the lathe........think of the space you'll gain!
The floor paint makes such a difference.......and is my biggest regret!
Mike
What a change, as I scrolled down I didnot expect such progress. It looks really good in there, hours of enjoyment to be had.
I regret not spending more time and money on the floor of my shed, your floor looks great!!
=D> =D> =D> =D> =D> =D> =D> =D>
Well done Boz. That is a real transformation!!! You make the most of it now won't you - lots more pictures of your compeleted jobs!!!
Richard
Thanks for all the positive comments. It is a much nicer place to spend time now. Just need to get on with the workbench - that table, and the Workmate alternative, are far too low and my back is suffering as a result :shock:.
Yes, very much a mixed blessing. It looks nice, helps with the light, and is easy to sweep clean. However it is like a skating rink once covered in sawdust :shock:. I'm trying to be positive and regard this as an incentive to try and keep tidier as I'm working, hence the broom easily to hand 8).
Boz
woodbloke":32ki4x8i said:
Hi Boz - nice 'shop...plenty of room for a p/t >>>>hat, coat, already running :lol: - Rob
:shock: :D
But that wouldn't leave any room for a milling machine :whistle:[dream on]
Boz
Very nice boz :D
I agree about the floor paint - I have painted mine a nice red and its amazing how well its stood up to the constant knocking about it gets
wheres that workbench you are making :roll:
Mike
At the moment Mike, the new work bench is a lot of ideas from a large folder of PDF's of other people's workbenches :). I do have some leftover MR chipboard from the flooring for the bottom shelf. I have a vice, dogs and Wonderdog. I have lots of ideas, some (like the deadman and dog operation) were tested on the old bench before it was demolished. And I've come to a full stop while I get the last of the boring round tuit jobs finished on this workshop. Once those are sorted I get to treat myself and spend £££'s on timber for the workbench :shock:
Eventually...
Boz
Top Job Boz. The floor looks great, but I don't like floor-paint generally. I put down some of those perforated-rubber doormats.
I have to pick them up now and again, and sweep out, but they aren't slippery underfoot. If you're clumsy like me, that's a bonus!
When I've got the energy, I can insulate my garage! Then SWIMBO will want it as another room I suppose.
:lol:
:?: Is it just me, or have the pics disappeared?
Or is it "So I thought I'd better set up a photo hosting account " a temporary thing?
SOUNDS interesting, would love to see the pics. Have floor paint for garage, but it's covered in ....stuff.... :roll:
The piccies are hosted on Fotopic, and are certainly still there. Unfortunately the embedded versions seem to be still unavailable this morning :evil:. I've checked the account and there are no warnings in the logs, so I hope it's just a temporary problem. In the past I've had no problems with Fotopic so a little worried about his :shock:
[Edit]
Right, I've rehashed the original post and embedded Thumbnails, which seem to always work, and then linked these to the 800x600 versions, via a different non-embeddable URL. Hopefully, one way or another you'll be able to see the images now :) Thanks for the comments.
Boz
Cheers Boz! Can see the pics, and can I say, it looks very professional in there! Better than where I work, and that's an inspection area... :shock:
All I gotta do now is....move stuff out, and paint a square foot, wait a week, cover that, paint a square foot, cover that - you get the picture - at a week a time (to harden) it'll take me 3 years and 46 weeks... :shock:
Must get my lean to sorted!
Can I ask (sorry) - what are French Cleats? and a "temporary deadman"?
Great stuff, Box! You'll certainly come to appreciate all this hard-work in six-months time once the winter really starts to bite! :wink:
Have you given any thoughts to timber merchants yet? If you're anywhere near Besselsleigh, I can recommend Deep in Wood from personal experience. They stock a good range of British timbers which, apparently, aren't easy to find in the Oxford area. :)
:D I took the alternative route and had a major clear out. Of course the "I haven't touched that for 20 years, might as well throw it" stuff was needed within a week :evil:
No probs. "French cleats" are a strip of wood with a 45 degree bevel on top. Screwed to the wall they provide a hook on which a similar, upside down, length of wood on the back of a cupboard or whatever can be hung. In my case I've just put long lengths along the top of all the walls so I can hang units wherever I want and move them to suit. When I make them that is...
A deadman, or more correctly a "Sliding Deadman" is a vertical board with dog holes in it that slides (left to right) under the front edge of a bench. So a long board can be clamped in a vice at one end of the workbench and the back end can be supported by putting a dog in a suitable hole in the deadman. I bodged a temporary one onto my old bench just to see how well it worked and see what might be needed on Workbench V4.0 :).
Thanks for that Olly. Yes, we are a bit limited. I'm a few miles north of Oxford and it's even more of a desert round here :(. I need to get on the phone. I do find timber yards a daunting place to deal with :oops:.
Boz
Boz, that's one of the main reasons why James (Binning) started Deep in Wood in the first place; he couldn't find the native hardwoods he was looking for anywhere locally (when I met him, he didn't sound like a fan of Timbmet, either... :shock:). I found him really good to deal with and happy to show off their setup (there was still a lot of work-in-progress, just so you know! :)). He's also slightly younger than me, I think (I'm 24) so, there's less of a reason to feel intimidated! :D
Boz,
Coincidently I have also almost finished the conversion/insulation of a single garage to a warm lined workshop, will post details when I have finished.
Also interested in any good wood yards NW of Oxford, I have used Powells in E. Oxford but seem expensive. Someone recently also posted a link to a place south of Didcot.
StarGazer
