tool-me-up
make sure the blade is of correct thickness for the saw aswell. I bought 1.5mm blades to find my saw would not grip them as they needed to be at least 2mm. I got round it with a big penny washer.
Myfordman":3loemwf1 said:It does not matter a toss if it loose
Within reason the fit of the insert in the blade is not important. For example if it were .5 mm smaller in diameter than the hole in the blade that would be of concern and would make it difficult to assemble the blade on the shaft, I am sure nobody would try to fit it.custard":baxopc85 said:Myfordman":baxopc85 said:It does not matter a toss if it loose
If it is loose surely it won't be concentric, which means it'll take a deeper cut and a lighter cut with each revolution. That doesn't sound like a good thing.
