Printing angle dimensions.
garywayne
21 Jun 2005
Bideford, North Devon
Hi everyone.
Just a quick one about Angle dimensions.
Once I have finished drawing up a plan, I like to print it off, including dimensions.
The question is. How do you get an angle to show up on your drawing, so as you can print it off?
Thanks.
Cheers Dave.
Before I download the ruby script, could you please remind me what to do, and where to put it. This time I will take notes.
The arc & text idea is a good one. (So simple). My problem is when I start thinking about something I get tunnel vision.
Gary, I gave you the wrong link. Use this one instead. http://www.crai.archi.fr/RubyLibraryDep ... m_angle.rb
Save the script in the Plugins folder under SketchUp. Make sure it is saved with the file extension rb. Also before you click on the Save button, look to see that sketchup.rb is there. If it is not, after downloading the dim_angle.rb script, open the Plugins folder and copy sketchup.rb from the Examples folder you'll find in Plugins.
You should find Angular Dimension in the Tools Menu when you open SketchUp.
Hope that helps.
I think it is just a snippet that could be added to another script. It looks like it can respond to certain inputs but it doesn't have the lines required to make it directly accessible from menu. I don't know much about writing Ruby scripts so I'm only guessing.
The first script calculates the angle between two lines, but doesn't put anything in the drawing. I assume it is/was a work in progress.
Assuming the .rb file to be in your plugins directory
1) Select two lines (assumed to meet at their ends)
2) Bring up the ruby console (Window>Ruby Console)
3) Type ang_betwen_lines (sic) and hit return
It will tell you the angle between those lines.
There appears to be one or two problems with the second script - it gets it wrong on lines in the x-y plane some of the time. But that's software for you. :roll:
Thanks guys.
I have tried to get my head round Ruby script, but I just don't understand it. How they can say it is easy I don't know.
Thanks again. Sometimes I wonder if some of us would get any further than just the basic drawing if it wasn't for people like you. [-o< :eek:ccasion5:
